turbo question
TYHOGG
It is possible to swap the exhaust housing of the stock turbo to a 57mm 20g? I can't remember what the difference is. I think the stock is a td0517c, and the other td0620g have the 14cm housing and its to large for a friends stock truck.
Thanks guys,
If anyone is interested I'm trying to sell the 20g. Its been on my truck for about 5-6k miles, no shaft play. Bought it new from Jerry @ deadbolt ent. looking to get $550.00.
-Adam
Re: turbo question
Thanks guys,
-Adam
No. The stock turbo is a 17C-TD06-8cm2, the 20G is a 20G-TD06H-14cm2. The big key is the '06H' is a bigger turbine (exhuast wheel) needs the exhaust housing to be machined. A 20G with a 14cms houng is going to need a bigger stall converter, maybe you could find a 10cm2 exhuast housing (though I haven't seen those in while)
TYHOGG
Re: turbo question
Thanks i thought that might be the case. I'll just sell with the housing as is.
It's just a six
Super Member
Re: turbo question
It is not a direct swap,but you can have it machined to fit the "H" wheel for the TDO6H-20G.
I had my 8CM housing machined to fit the "H" wheel.
Spooled very fast.
