So I've started to buckle down and start getting the parts together for the up and coming typhoon tear down and build up. I'm building it right this time and fixing PO stuff that's been a problem since I've owned the vehicle. On that, I want to upgrade the turbo from the PTE 60 turbo that's on it now, to a PTE 67 turbo. I'm looking to be able to hit the 10s but I don't want to go too big and lose the grin factor of driving the typhoon on the street. It will primarily be driven on the street so that's where I'd like to focus. I'm going to build the engine so it will handle the boost and also swap it over to FAST XFI. The typhoon already has the A2A setup and 3 inch cat less down pipe. Thoughts? It looks like BB turbos are about 800 more than journal bearing turbos. With only a few hundred RPMs spool up over journal bearing, is it worth it especially with an auto? What about other things I should be looking into, I'm looking for thoughts and suggestions. I'm going to do a build thread when I get back off deployment. I don't want to start one now and then no updates for 6 months. Also, using that time to buy the parts I need. Just bought the vortecs and modded intake. What else... Especially turbo thoughts. Thanks in advance guys.
