Turbo Rebuild Help
So my compressor blades are bent and there is oil leaking into the housing, so i need to rebuild my turbo. I just want to make sure i get the correct parts for it. And I dont think this is a stock turbo either. The numbers on the compressor housing are: 49179-04100 And next to the Mitsubishi symbol are: 49179-54900
And on the exhaust housing are: DUCM 79-1200
From the research i have done, this is the closest thing that i can find: https://www.hahnracecraft.com/products/compressor-wheel-td06h-20g?variant=21021176773
Im just not 100% sure its the correct part and i dont want to waste money. I also need to replace the seals and what ever bearings i need to replace in the cartridge. Any help is greatly appreciated! And this is a Syclone too Btw. Thanks!
Jay92Ty;n1861267 said:
Yup, those numbers are leading me to the exact same pages. I believe im on the right track too, now im just stuck with 2 different compressor wheels. The one in the first link i listed and now this one:
turbocompressorwheelmitsubishitd05hevo316gdsm
This one is cheaper, and manufactured by Kinugawa.
So my parts arrived today and i rebuilt my center section with all new Mitsubishi parts and it all went perfectly. My compressor wheel was exactly the same and fit perfectly too. So i got the right parts. My only concern is that on my new wheel, 2 of the fins have a little burr. One on the tip of the fin and one at the bottom. Should i be concerned about this? Or should i just gently file it down/leave it alone? I really dont think it will effect anything at all, but i know it shouldn't have any flaws when its brand new.
Other than that, it spins perfectly with ZERO play in or out, or up and down.
Jay92Ty
I think you be ok IMO if you file it smooth. The ooonnnnllyyyy thing I can think of that could possibly happen would be an unbalanced wheel?, but might be to small to create any fuss. Just a thought!
Sorry i never saw your reply for some reason. The turbo is working perfectly fine so far, so i think we're good. Thanks alot for the help!
