turbo rebuild ?'s
TwistedTy
More boost! N.A.S.T.E
I have some shaft play in my stocker, now my question is would i be able to rebuild the stock turbo with some sort of 20g wheel upgrade? i tried using the search but couldnt narrow down anything. Would it just be wiser to buy a new one? :-?
Boosted
everything i found when reasearching was that a 20G upgrade was in the 800. range. I specifically remember Hahn Racecraft at that price. I would be more inclined at that point to investigate to see what RPM or TurboTime would have available. I thought some of the kits were 1300.00 or so, and they may have something lower costed that is not advertised.
KETCH-UP
20 G
20 G
I had a stock turbo rebuilt with a 20 G wheel stock ex. housing and I like it. It spools the same as stk. and with the ult. chip it pulls to 20 psi vs. stk. that heat soaked at 17 psi. Prolly gives 25hp gain. The wastegate was also ported, and this gave me much better boost control with stk. chip and ult. chip. The small ex. housing gives lott's of back pressure and this limits the gains some vs. a PTE kit. "Waller" on this site performed the up-grade. :)
jwaller
Evil Genius/SyTy Guru
I normally get bout 450 for this upgrade, and I need your old (good) turbo to upgrade as a core. pm or email me for details.
Justinf74
possible rebuilt turbo for the syclone
$450 doesnt sound bad at all, do you rebuild turbos on the side, if so how can I get some work done to mine, thanks
