Re: turbo removal/install questions
For the oil feed line, check out
this post. It should be noted that if you opt for this type of installation, you will need a 1/4 X 18 NPT plug to plug the block where the stock oil feed line was plumbed. And have *fun* trying to get the stock one out from behind the motor... For the oil return on my truck, I had a flange that bolted to the bottom of the turbo and connected to the stock oil return line. Smeared a little high temp RTV on the flanges to keeps leaks at bay.
The water lines ain't no picnic either. You will need a 3/8 X 18 NPT plug for the port in the lower manifold for the stock coolant return line. The supply line that is under the truck, is a
ROYAL PITA. I have done this to three trucks including mine. The other two owners didn't want any part of doing this, they know who they are
... Be ready to get a nice shower of coolant since you will be draining the block once you break the fitting loose. Just getting on said fitting will be a challenge since you will have NO room to where it's at (a few years ago, a member on here said that it was impossible to get that fitting out
). Getting on it is only half the battle since you also have to break it free without rounding it off. Just like all the plugs that I used on my truck, it's made of brass so it's soft. Round it off and you are going to be up that particular creek without a paddle in a big way. Gonna need either a 3/4" wrench or a 19MM one to remove it BTW. It will take the same sized plug as was used to plug the stock oil feed mentioned above, 1/4 X 18 NPT.
Lastly regarding the downpipe, check out this post
here The easiest way to get the nuts off is with the "double wrench" trick where you slip one wrench into the other one and/or use a deep well socket. You may have to use the double wrench trick on the turbo to downpipe nuts. If that be the case, you will have to use a double open ended wrench to do it with a closed end one for leverage... Deep well sockets work great on the turbo to exhaust manifold nuts since they are thin enough to get in there after you tap them on with a hammer. If you haven't already done so, I would
HIGHLY recommend that you remove the wheel wells and front wheels doing this! HTH's
