AlaskaTy
I haven't driven my typhoon for about 6 months and finally took it out. At first it didn't want to start and then reluctantly it finally fired. repeat starting attempts are accompanied by starter click and then long cranking periods before it'll turn over (fresh plugs, wires, cap/rotor, oil).
I had to drive it about 2 miles to my new place and it smelled like hot metal. The engine temp was good, oil pressure was good, fuel pressure was good so I just took it easy. When I got home there was a small amount of smoke comming from the rear of the driver's side cylinder bank. There were no flames, but the smoke would keep comming and comming. leaning over from the passenger side I was overwhelmed by the heat of the turbo (way hotter than I've ever felt before). Has anyone ever experienced this? Any ideas of what might be causing my turbo to heat up so much (on the 6 minute drive I only got up to about 2-3 lbs boost)
Right now I have an exhaust leak at my #2 exhaust manifold flange, and it's got a pretty gnarly missfire that I need to figure out too, also the throttle response is nill, and when I do a slow hard turn the engine tries to stall. I need to get this thing running well in the next 2 weeks...so I need all the help I can get. Thanks.
Jason
Jason
