Everything else being equal, does running something like a 20G or a te44 at 15psi make the overall system less likely to detonate than running a stocker? I've just been noticing that a number of people seem to have said that they've upgraded and it's usually knocked a few degrees off their KR, or that they can run a few PSI higher than a stocker with the same KR. (which would make sense at higher boost levels of course)
Not saying that it's a good way to combat excessive KR, just wondering if it's a trend where you have a few degrees of KR, bolt on a slightly larger turbo and see those drop. For those who have done it, would you attribute it most to the more stable boost control (less spikes to make you knock), the much lower exhaust backpressure (and heat), or being on a much better part of the pressure ratio island? Combination for sure...
But really, would you say that statement is generally true, at least for the stock to 20g/te44 leap on an otherwise well running truck?
