sean
building a ty clone engine need help on turbo. going 30 over, srp piston,eagle or oliver rods, nitroed crank, 412 cam, 96up vortec heads 202 160 valves port and polish, porting and polishing upper and lower intake, 50# injectors, raceproven fuel rail from mike, bigger fuel pump, going to use elictric boost control, would like to keep my a/c and will be using stock manifold. the ony thing is i would like to be able to use the truck an a daily basis but able to race it also if i wanted to. what turbo do u guys think i should buy?
