turbo swap
Ryda85
Senior Member
what turbo will be an simple bolt on swap if the truck now has a garrett t-44, atr downpipe and atr headers.
Re: turbo swap
I assume it has the ATR 3-4 bolt adpater. If so the exhuast housing is that of a GN/Ttype, so most of PTE's GN turbo's will swap PT51, PT52, PT54, TE60, TE45, etc or some of the 72 series Turbo's., but you will need the GN turbo exhaust housing not the SyTy specific exhaust housing.
ghettosled
SYTY SUPERSTORE
Re: turbo swap
You can use the syty housing from PTE, but you will need to oblong several of the bolt holes in the DP.. that would be my suggestion to eliminate any leaks you may have with the adaptor.
