turbo timer
juicehead9
93 Typhoon # 0973
Re: turbo timer
I would like for some way to run ele. fan for a few min. after i shut it down. My Grand National used to do that.
juicehead9
93 Typhoon # 0973
Re: turbo timer
is there a way to keep to fan running with out haveing to go back and cut the switch off? I ordered Erue's ele. fan install kit.
Wikid 1
200+ lbs of puppy!
Re: turbo timer
you can get a delay timer relay if all you want to do is keep the fans on. probably at radio shack. would be pretty simple to just splice inline so that once power is cut, it will stay on for X amount of min or sec based on which relay you got.
