Turbo tweak chip setting question
vinnieTy
TY # 1889
I reached out to Eric at turbo tweak on an issue i'm having when i get into boost and i just want to post it here if anyone has had a similar issue and if so how they went ahead resolving it. Eric stated i should adjust the turbo rod but i'm not sure if i want to make any changes to it on my stock truck.
First i must have to say that this post is in no way stating Eric and his products are at fault. I think the support and the product are great.
Whats happening is the truck goes into boost hits about 8 pounds then gets out of boost for a second or two then hits high boost 15 or so pounds and stays into boost its just the first beginning part. I'm trying to get a continuous boost flow. I have not made any changes in the turbo tweak settings because i'm not sure what changes could resolve it.
Thanks in advance for the help.
Eric Sy GN
Re: Turbo tweak chip setting question
I've been working on that over the winter. It has to do with the transition from open loop boost to closed loop boost control.
I've made some tweaks to the logic to help out.
Shoot me a message and I'll send you something to try out.
Regards,
Eric
vinnieTy
TY # 1889
Regards,
Eric
PM sent! Thanks Eric. Just like always your there to help!! OUTSTANDING!!
