turbo wastegate question?
syclone666
Hello I just finished my rebuild for my 91 Syclone. But, i have one problem where do you get the vacuum from the motor to the turbocharger. Do you get the vacuum from the throttle body,EGR value? Please Help!
Re: turbo wastegate question?
There is no "vacuum" used here. It's all pressure. There's a fitting on the outlet of the turbo that goes to the solenoid and then one from the solenoid to the wastegate actuator. The passenger side fitting goes to the turbo and the upper drivers side goes down to the wastegate actuator itself.
