Hi. Is there any easier option to replace original water line which goes to block? I'm not sure is it reliable and sure it's hard to replace if it breaks.
I am sure you could do a stainless steel braided line with some nice AN fittings. You would have to play with the routing a little bit because you obviously don't want it resting on the exhaust but it would be a rather cheap project I think.
Measure out the current line, cut a piece of rubber hose in that length and mock it up to check clearance and bends and all because you made need to lengthen or shorten it then figure out the ends that you will need as far as bends and order it. You will have to get the pitch and size off of the old line.
siliconeintakes.com has all the stuff to build stainless lines as does JEGS and summit I am sure.
My ty has been running without the water lines now for 3 years. Most aftermarket turbos don't have provisions for running water lines so I don't think it would be a problem. I would just make sure to change oil regularly and let the turbo cool down after a hard run before you shut the engine down. If you really feel the need to have the lines, http://www.sytyperformance.com/inde...facturer_id=0&option=com_virtuemart&Itemid=26
Just get some 3/8" fuel line hose and use that. I put a 90 degree hose barbed fitting in the bock and just ran that for both coolant lines. The coolant helps prevent cooking the oil as well, but it you don't mind changing the oil all the time, take them out.
Hmmm. This is getting me thinking. My truck is gonna have a pretty easy life so I don't see a whole lot of WOT / full boost type situations other than fun runs on the back roads. I may look into getting rid of these.
I'm running a turbonetics T3/T04E bb turbo. Currently the cooling ports are plugged, but I spoke to a tech at turbonetics today and was told I SHOULD be running water cooling. The cartridge was designed to be cooled in this way, for my model turbo anyway. He also mentioned their turbos use mostly 16mm fitting for cooling, like many others, but you may find some using 3/8 fittings being used. Prob custom order. He recommended tapping/Teeing the hoses coming/going from the heater core. Seems easy enough i guess...a little write up below.
If you ever tear a turbo down and can compare a water cooled one to a non-water cooled turbo, it will make you stick with water cooled. The only way I'd use a oil only bearing housing is if I had a turbo timer, even then I'd be iffy.
