I used Turbolink with a truck over the weekend, with the latest vehiclepak (i'm pretty sure it was the latest). Pretty cool software.
The dashboard display was very cool, I liked that a lot. I thought the gauges/numbers might update faster though. I do have a 366mhz laptop, might be something that is cpu intensive. I did make sure the update rate was set high. Since the dashboard display is xml based, when you resize the window, the display will have the components located correctly - so if you have 800x600, the gauges are kinda scrunched, if you are at 1280x1024, the window can be maximized and the gauges/readouts will be spread out & more legible.
The details page was nifty, displaying some fields that datamaster didnt, but that might only be of use to people doing serious tuning. This display is the one most like Datamaster IMO.
The strip chart did disappoint me a little bit. I've used similar displays in Datamaster and WinSP for FAST. On FAST - it displays all the channels you have logged, up to 14 or so. On Datamaster it will display 4 at a time. In Turbolink, it will show 3 different displays, 1 channel per display, with a drop down box to change to whatever data you'd like. It does take a second to load that data. You can change the frame width in the settings before you connect, but it isn't possible to change while you are actually recording or reviwing a run. Datamaster is written very well in this respect. It is probably the most useful feature of Datamaster IMO. The way I use this screen (on any of them) is to change what channels are displayed, and look for low/high numbers, or sudden changes... that is best displayed in a graphical manner. You can see trends - like intake air temp climbing during a run, or boost going out of control. Being able to pinpoint those issues is very important, if you have to play through the whole run in a slow fashion, it can be quite annoying. Datamaster allows you to zoom in on any portion, and move the cursor around displaying all the data in each frame, and does it very quickly. Turbolink is a bit clunky here, but still very usable. If there was some way to easily zoom while within the strip chart display, it'd be very nice.
I didn't get a chance to setup any of the audible warnings, though that is definitely something I'd like to use. Have to save some interesting wav files to my laptop 8)
I didn't try any of the triggering mechanisms either, but they look pretty easy to use. I'm still unclear if the triggers will shut OFF logging though.. ??
This would be great to create very small logs for 1/4 passes and such, based on boost, or throttle, or vehicle speed. You have enough to worry about during races, I'd love to not have to even touch the laptop until i'm sitting in the pits - start the laptop & software up, go thru staging lanes, go race, come back, park, check out the log.
