Turbonetics.?
syclone3
Re: Turbonetics.?
TO4B is sort of older technology. Doesn't mean it won't work well. How much HP you want to make and what psi range? I have used about ever size of TO4B and E series of Turbonetics turbos on various engines.
Damian
Re: Turbonetics.?
That would be pushing that T04B wheel pretty good. That's pretty much the max hp output of those. It's still a pretty good wheel though, used it on my turbod 3.5l Eclipse. But that exhaust turbine is pretty big and won't fully spool till about 2800-3000 rpm.
Damian
Re: Turbonetics.?
Get it with a smaller exhaust housing unless you have a higher than stock stall converter.
jusssi
Re: Turbonetics.?
Actually I have +200 rpm stall converter. I'll try with that housing, let's see how it works.
jusssi
Re: Turbonetics.?
Yes, I already have a wg housing with 3" v-band outlet. I'll fabricate custom dp.
