Turbotweak/ 60lb injectors
cdprayor
Finally got around to getting my 60lb injectors and turbotweak chip installed today. Does anyone know what the fuel pressure should be set at for this combination? Drove it around town for awhile and when I decided to open it up, it was struggling to get over 3500 rpm's.
Eric Sy GN
Re: Turbotweak/ 60lb injectors
Start at 43psi line off and go from there (see chip instructions).
Do you have something to datalog with?
cdprayor
Hey Eric. I sent you an email earlier. I will get you a datalog later this week. Thanks
13.robb
yes, 43 psi. i had to crank mine up quite a bit to get it to run. I still have to get the logging software, I'm running rc550 injectors, so i'm sure it will be fun to get right! But i found out this afternoon a friend has a hook up at iroz motorsports (audi guys) out at the speedway and they have an awd dyno !!!!! Other than that i've been dragging my feet, working too much. etc. but it is all finally starting to come together!
The plx wideband is pretty bad azz that i got from you eric. Thanks!
cdprayor
I hear ya about working too much. I thought this would be our last Saturday to work so I could do a datalog but nope 1 more Saturday of work. I set my fp at 43. Seems to run a little better. Idle is still rough. I did notice on my snow meth display it has pw%. I assume this is pulse width %. At wot it's up and down between 70%-75%. That's where it begins to surge and kinda fall flat on its face and rpm's will not rise above 4200-4500. Any ideas?
Eric Sy GN
Are you spraying alky? I don't think I made that chip for alky. If that's the case, then it might be too rich. When I make an alky chip, it has less fuel up in boost (although you can tune the fuel out yourself also).
Eric
cdprayor
Yes I am spraying meth. Actually with or without meth doesn't seem to make a difference. Rpm's kinda hang around 4200-4500 and finally shifts. God I need a day off to do some datalogging
cdprayor
Seems to be running better. Need to do a little more testing but I had to turn
the fuel down quite a bit at wot on the dial settings.
