TurboTweak
Tony Dipatri
I was having trouble with my since the new motor went in. The fuel map was all over the place and I was having trouble choosing between Code 59 or Big Stuff/DFI/Eccel. Since I was running low on money I purchased a Kit from Eric @ TurboTweak 65LB Injectors/3Bar Map and a Velosyty Chip. I had a good friend on mine Jose from Jose MotorSports help me install the injectors and chip.
I started the truck and I don't smell raw fuel anymore and the idle is good so far and the A/F is where it should be. I still have to drive it so it can learn. I had quite a few PM's wanting to know how this works out and I will post on Monday when I drive it on the street and start logging some data. I can now start driving my truck and finally enjoy it.
I plan on going to Code 59 in the near future for when i decide to either go faster or just to learn tuning for myself. Frank from Auto Addictions offered to install Code 59 and tune which is probably the way I will go.
I will update this thread on Monday
Tony
Scubanme
Re: TurboTweak
Hey, good to see you finally got the Big Stuff that you were talking about. The tuning always takes some time to get dialed in, so take your time and don't rush it and always play it safe.
Tony Dipatri
Re: TurboTweak
Tony, Did you get your vacuum lines straightened out since Frank's meet?...Jim
Jim, I installed the vacuum kit from Sportmachines when we installed the new injectors. When I took the plenum and inter cooler off there were more split hoses. The kit was well worth the money. Eric from Turbo Tweak is working with me on the tune and tuner pro connectivity problems.
Thanks for your help at NASTE
Throws
Re: TurboTweak
I've had no issues with mine. In fact... I love that "Check Engine" is now used for a knock light. ;)
And... as a bonus, they're sending out new chips since they updated the programming.
Just wanted to let you know, I'm sending you a new eprom chip with the latest programming for the Velosyty chip. I just recently did a couple tweaks to the programming to touch up some things on all the Velosyty chips, so I want to bring everyone up to the same version. I will be sending just the EPROM (chip), not the whole memcal adapter. There is no need to send the old chip back to me. If you don't feel comfortable swapping the EPROM, feel free to send the whole thing to me to change it. It's pretty easy though, just plugs in. I'm sending some instructions with it.
I'll be sending it out in the next couple days. Let me know if you have any questions.
Regards,
Eric
-P
tech9
ABS Expert
Re: TurboTweak
Got my new chip, before reading the email I thought I accidentally got someone elses chip, but no a free upgrade ;)
A-BomB
Re: TurboTweak
I'm thinking of getting a velosyty chip too. Does anyone have a dm file I can look at for a stock sy?
alwayscode390
pppssssshhhhhtttttttttttt
Re: TurboTweak
I am going to be interested in going with a TT chip in both the SY and the TTA ... but may go the RPM route on the SY ... not sure yet (or I may get a dyno tune if I can find someone local that can tune obd1) :) ---
alwayscode390
Re: TurboTweak
I have never gotten a CHIP before ... and am worried about getting on the dyno and having unsafe A/F ratios. I just dont quite understand how you can get a dead on tune for your setup this way.
If you arent happy with the chip do you just tell Eric, and will he adjust it until you get to a happy spot? Does it cost to have it reflashed?
Eric Sy GN
Re: TurboTweak
Hi,
Yes, we will work back and forth to get it right. However, the chip has built in adjustable features, so you can make tweaks yourself, as long as you have a scantool. Also, if you have a wideband, you can connect it to the ECM and it can be put into closed loop mode at WOT to help the tuning process (like an aftermarket ECM). I highly recommend a scantool and wideband O2.
There is no charge for changes to the chip for a period of one year (within reason), as long as you don't change your injectors, or change your whole combo (turbo, heads, etc). When I say "within reason", some people try to "over-tune". In other words, they only look at A/F's and try to target certain numbers, and end up in a never ending cycle of chasing A/F's. My main concern is good driveability, the least knock, and good power.
As far as an unsafe A/F on the dyno, you should always start with the boost low and work your way up. I typically would rather see logs from a run on the street or track, rather than a dyno run.
If all else fails and you're just not happy, you can send the chip back and we can do a refund or credit depending on long it's been.:)
Regards,
Eric
It's just a six
Super Member
Re: TurboTweak
Eric,
Just curious what adjustments can you make w/your chip & how can a person make the changes?
I see the knock indicator only shows if knocking is greater than 4 degrees, is that because anything under 4 degrees is not much to worry about?
Thank you.
Re: TurboTweak
Eric,
Thank you.
You been here a while. Have you not seen any info on this? Its been posted.
http://www.turbotweakstore.com/ProductDetails.asp?ProductCode=1002
I guess those are for adjustments on the left
Available now for stock injectors and 60lb injectors.
A completely new program for the Syclone/Typhoon! Many improvements to the chip programming to improve cold starts, idle, response, and general driveability. Can be programmed for the stock 2-bar MAP or a 3-bar MAP, although a 3-bar MAP is recommended for better boost control. Also includes the ability to read a wideband O2 system (connected to the ECM), and makes corrections at full throttle (above 10psi boost). The stock O2 is used at the low end for best driveability.
The chip is mounted on a memcal adapter. You remove your old memcal and plug it into the new adapter, then plug the adapter back into your ECM. (You need an old stock-type memcal for it to work.)
Optional secondary program can be put on the same chip ($55). It is selected by a small switch on the memcal adapter, or you can install a switch to enable the second program.
Knock Alert, flashes the check engine light if knock retard exceeds 4 degrees
Also includes user adjustable features. These are adjusted using a procedure with the throttle and watching some numbers on a scantool.
User adjustable features are:
1. High boost fuel
2. Mid boost fuel
3. Low gear timing
4. High gear timing
5. Initial wastegate duty cycle
6. Target boost
7. Closed loop WOT A/F target (requires a wideband system connected to the ECM)
Download chip instructions here: http://www.turbotweak.com/velosytydoc.pdf
[/QUOTE]
alwayscode390
Re: TurboTweak
Will Powerlogger or Tuner Pro work for the Sy and the TTA ... so I dont have to buy two programs?
Which of the two is the most recommended? ---
Flyin Ryan
hated cuz he drives fords
Re: TurboTweak
Eric,
Thank you.
You can make adjustments to timing, boost, etc via your gas pedal while looking at your datamaster or tuner pro app
Eric Sy GN
Re: TurboTweak
There really isn't a good logging program that works with both. Tunerpro could work on the Buick, but the Buick's ALDL output is really slow (just the ALDL output, the ECM itself is plenty fast).
I like Powerlogger on the Buick, and Tunerpro on my Syclone.
Eric
