TurboXs Knocklite REVIEW
Deanzsyclone
Did I put this in the right forum??
I want to write this while all the details are still fresh in my mind. I ordered this TurboXs Knocklite and Bosh knock sensor over the Internet and tonight I finally got around to installing it. After the install I went out driving around using up a FULL tank of gas testing this thing out.
Let me tell you first off I don't have a knock sensor at all, since I'm using the big stuff 3 ecu we just have not gotten around to installing one that works with the BS3. So not having one seems to always keep me curious about getting one so I have been doing allot of reading on the Internet and found that the Subaru and EVo guys have been having some good luck with this knock lite, and one thing that caught my eye in a big way was the fact that the knock lite gets tuned for your application. Hmm that sounds interesting I thought, how does it get tuned.
First off after wiring it all up, you need to put it in tuning mode, then once in it, you leave your truck at idle and press the button on top of the light, at which time it listens to your truck to hear it's various sounds it makes, rotating assembly, lifters, rockers, ect. Then you run the RPM's up to 1/2 of what your red line is, 3,500 for me, and then press the button, and again the sensor listens to your engines characteristics, and records them, then run the rpm's up to slightly under red line and press the button one last time, and it takes a final recording. Now it knows what your engine sounds like with minus knock, since you were in neutral the whole time of tuning. So it's this interesting idea that made me want to order it and try it out for my application. Note, medium knock is indicated by a amber light, and sever knock is indicated by a red light.
Real world testing. So tonight I load up my program for 91 octane gas after calibrating the Knocklite, and I start off with only 10lbs of boost to see if it picks anything up. Ten pounds gets me nothing on the lite, so up to 15lbs it goes, which is where I was told it's tuned for, but if I want to go higher than that no guarantees. lol.. OK, I got Yuh. So 15lbs still shows me nothing but the instant I let off the throttle I do get blow off from the waste gate and with that I get a red blip, just for that brief 1/2 second. This seems to take place every time I get out of the throttle. I think it was even happening during my 10lbs pulls. So now I'm wondering where knock will be present and I turn it up to 20 lbs but only ease into the throttle slowly and watch the boost climb while watching the knocklite which is locate next to the boost gauge, still no amber lite and no red light, with the exception of the blow off valve releasing. Hmmm so I'm wondering if this Knocklite is really very good or maybe my sensor is in a bad place. By the way it's bolted to the block right next to the turbo, at the hottest cylinder, aka the last one to get coolant before it returns to the radiator. Now keep in mind, during my pulls all I hear is a nice smooth engine accelerating, I can't hear the tink or ping of any detonation my self, and I do know what it sounds like. My truck is loud, but that unique sound is easy to spot when it's severe, especially with the windows up. But with this new build I can say that I haven't heard it yet. Any way's, so now I decided to turn it up to 25lbs and ease into it once again, (I can see Mike rolling his eye's now..lol ) being prepared to jump out of it. Again all I hear is a very smooth motor and beautiful hum as it eases up to 25lbs still with no amber lite or red light popping up.
Ok so this thing must be junk, their must be some knock going on, even knock I can't hear should be giving me a amber light. Sooo I have one last trick up my sleeve!! I realized that my c-16 program has more advanced timing and maybe some leaner fuel, and I'm running 91 at the moment, so I should get some detonation even on low boost with 60% or so throttle position. So I load up the c-16 program and turn the boost down to 10lbs and continue on my way down the freeway, I slowly lay into it watching the boost climb and as it gets to 9-10 lbs finally the amber then a couple of blips of red light come on! Hey this thing is picking something up finally. I never even hit WOT but still got the knocklite to activate. I tried this two more times and got the lite to come on both times, but I have to tell you I could not hear ANY pinging going on even though the light was saying severe. I'm very well aware that I can't hear the pinging/knocking until it get around 10degrees knock retard, which is high, and audible. I heard none of this but the lite picked it up.
So back to the 91 octane program I went, and again ran the boost at 15 then 20 then 25 with no knock lite activation!!! I was to scared to go to 30#. Twenty five pulls like a freight train.
So what does this all tell me?? Well first off it tells me that this knocklite does indeed work, and seems to be VERY sensitive, but that can be turned up or down after tuning is completed. Note, I had the sensitivity MAXED out on my knocklite after calibration as I was getting frustrated it was not lighting up unless the blow off valve was discharging. This also tells me that this combo of mine, Brodix alum heads, ect ect, rea lly work fantastic to reduce knock, and that I think I have been blessed in such a great running and tuned truck. Returned home and the truck was purring like a kitten : )
10-08-07 UPDATE *********
Well after running a Yamaha R1 the night after testing I found the knock lite to be lighting up with sever knock only to jump off the gas like my foot had been electrocuted. After reflecting back why it now was knocking the night after my testing I realized that when I tested the system/lite I would set boost for 25lbs and simply raise the throttle till I hit my target boost 25, while probably only running at 70% throttle, not enough to make the truck knock at that boost level. Of course while running the R1 it was at wot from start to finish/throttle release. So back to 15lbs for 91 octane. R-1 story coming in syty kills. Sorry about the false impression I gave above, but it was good to see the light was working, heck I could even hear the knock...UGH. Trucks fine though, just got back from a 200 mile drive.
Test Conditions the important stuff.
Cool late evening air
Lots of open freeway to do some 60 to 120 mph blips
91 octane fuel
t-72 turbo
Brodix Alum Heads
Cust Cam
Big stuff 3 and Custom tune
Really good hearing : )
KB air to air
NO METH INJ
72# Injectors
Bosch Knock sensor #0261 231 006
TurboXs knocklite
Patience.
hatrik8
Re: TurboXs Knocklite REVIEW
Nice write up. Are you saying you have no knock at all 25# on 91 octane?
Deanzsyclone
Thats the conclusion I have to come to after testing it like I did. My next step is to run my dump into the exaust so I can hear more of the motor. But I do have to say the sound of detonation is very distinctive from other noises. But eliminating that dump will help me feel even better that I'm not hearing any deonation.
clone 94
very good write up. i have a knocksenseMS setup wired into my holley commander ecu that i'm still playing with. it seems to work though i have never registered any knock with it, i'm kind of skeptical of it at the moment. i'm running 15psi with an aggressive spark map and meth injection though
thanks for the info, i'll be giving this a try with the new engine/bowtie head setup waiting for my current motor to break
Ground Rat
Thanks for the writeup! I have been thinking about picking up a standalone knock monitor.
