with a piston stop...
you turn the crank until #1 cyl comes up and hits the stop..make mark#1
then you turn it in the other direction till it hits the stop..make mark#2
the point in the center of those marks is TDC.
CavScout said:Can do/will do first thing in the morning.
But, nobody knows why I have two marks on the balancer?
MikeRenz said:i was told the second mark is for the vans becuase you can't see the thing from up top. They have a timing tooth mounted on the bottom of the timing cover also. Just paint the mark you use white or yellow or something bright. You'll never notice the other hash.....you shouldn't see the other hash at all or you're way off.
btw...the top mark is 10 degrees off of the key of the crank.
CavScout said:That fixed the whole dern thing, cranks over like the chump I am. I'll finish timing her up, check valve lash, get a tag and insurance tomorrow.
CavScout said:No, we're re-checking lash because of a ticking noise, heard on initial start-up. Just a precaution. If it doesn't tick tomorrow, then we won't.
I ain't a pro engine builder, just a nervous idiot that really wants to do this right (the first time). Got some advice?
