myclone
Ok... Got ERUEs/Sigos old Ty put back togeather and have been looking at it on datamaster to see how shes behaving... Well, she's not..
Here be da prob. Boost is all over the place between 10 and 15psi. Knock is... well... tolerable. Getting a max of 3 deg KR at shift points intermittently.
Heres what weve done so far.
New plug wires
new cap rotor
swapped boost selonoid
changed all vacuum lines to silicone
160 deg stat (goes into closed loop fine)
checked timing to verify on zero in set timing mode
FP adjusted to 44psi. (still tinkering with that)
Have monkeyed with the WG rod to make sure its good to go. Its maybe one turn too tight now but it didnt hurt/help the boost fluctuation no matter where its at. Im gonna put it back where its sposed to be anyway.
Truck already had a shurflo IC pump, walboro 255 FP, relocated IC hoses, AFR..
Truck is stock otherwise. Has full exhaust with non gutted cat.
So where do I start. This is my first experience with a STOCK (more or less)syty and Im up against a wall on the boost fluctuation. The boost variance doesnt follow what little KR I get at all so Im assuming that a fluctution of 5+psi is caused by something else or partially something else..
TIA..
New plug wires
new cap rotor
TIA..
