Re: ty carpet replacement
warmpancakes said:
does it have the heel pads like the original? did it come with the Jute like the original or was it just the carpet?
I'm not too familar with the 'lingo' such as Jute.. but I'll try to describe the carpet best as possible and if that doesnt work I can go out and take pictures and pull back the carpet around the drivers/passenger side and get some shots of what it looks like underneath for you.
Basically the carpet is a bit thicker than the original, it feels high quality and the thread density is pretty high.
In the area where your feet go .....
screw it, im gonna go get pics.. brb in 10 mins
edit: here are the pics (wow i need to vacuum!).. larger versions can be seen at
http://picasaweb.google.com/epixpc/TyphoonMisc
Drivers Side:
Here you can see the 3 layers under the 'heavy traffic' area.. there is 1st the carpet, then the padding, then the insulator that I have added.. the padding from what I remember is not in all areas.
If you got anymore questions or need more pics just let me know
-Pete
