Plan on doing a tune-up every 4 month ( plugs, cap-rotor)(wires once a year) Do your oil change every 2,500 miles & trans, diff ( front & rear) every 12,000 miles. The last 4.3 I ran lasted 320,000 miles before my son wreck the truck it was in, so I remove the engine & am putting it in a 88 S-bed S10 with a 5 speed just to see how long it will last. You should know that the engine still doesn't burn any oil at all between oil changes & still has 40lb oil press at idle (hot) 65lb oil press going down the road. On this engine I did a tune-up once a year on everything because it's not a turbo. The engine still got the same mpg as the day I first did a engine swap 17 city & 22.5 hwy & would smoke the tires in first bark'em in 2nd & sometimes in 3rd with 3.73 posi gears, However gas mpg would drop when I drove like that...
