Ty is stuck in one spot
Osmosis
I am pretty sure my pump in my transmission is shot. A few months ago, I noticed a tick, tick, tick coming from the torque converter area. Initally I thought the tick, tick, tick was an exhaust leak....it was not:( I fixed where I thought I had a possible exhaust leak and when I got on the throttle, I had a huge slip in the 1-2 shift. I drove her home and she has sat in the garage since. I start her every week but she has not moved. Today, I moved her out onto the lawn to wash her. A few hours later, I started her up and went to put her back in the garage and nothing, no Drive, no reverse, 1,2,3 ....Nothing:( The previous owner had all the paperwork for the rebuild of the engine and transmission. I suspected that the pump in the transmission is the problem. She never slipped until I had the slip I mentioned above.
I was kind of hoping to save some cash and just throw a pump in the trans since I have receipts for the rebuild...pump was not one of the parts in the rebuild kit, just a basic stage 3 rebuild kit. The trans has 15K miles on her if that.
Any thoughts on this? :rant:
Slyclone
Well-known member
Re: Ty is stuck in one spot
Hey don't feel bad my syclone is stuck also. It does not shift second. I put a thread up about the tickinng I heard under the driver seat and was told it is the govenor. I don't know. Your suggestion is pump is shot my problem is I don't want a high dollar trans that is not going to perform like the original.yea check fluid on level ground and smell and inspect
Logan
I know that ticking noise and yes that is probably the pump. You won't have anything because the fluid isn't moving. A good way to screw up a front pump is the not properly install the TC when putting the trans back in. As far as only doing the pump I don't know. I would inspect the fluid and the valve body and if you see a lot of shavings you are probably going to have to take the hit and rebuild the whole thing. I am not an expert at Trans stuff so I don't know if pump shear to pieces or just cease to function.
Osmosis
I did replace the converter when I first got the typhoon. I did install it correclty so I know that's not the cause. The trans was rebuilt at 148K miles, no pump was replaced or installed on the rebuild. When I pull her out, I"m going to inspect the valve body for shavings and such. Once I pull the pump, I'll make my decesion. I'm just gonna take my time with her, hell, I only have put 12K miles on her in the 7 years I have owned her. She's a garage queen. I figure the transmission will be my winter porject. Heck, I may pull the heads off and port them nice, maybe a new valve job for some extra HP..or find some L35's:tup:
As for now, I have to push her back into the garage:roll:
Logan
I have two sets of 140 casting number Vortec heads if you have any interest. Good luck with that build.
Jimmy
Banned
There is basically never an easy fix with these glass transmissions. 99.9% of the time a hard part is broken inside it,and when you fix it with the best stuff $ can buy,it will explode again.
Osmosis
It's been while since I've had any free time to post or work on my Typhoon. I've been way too busy to work on her till now. I finally put my baby up on ramps and jack stands and drained the transmission fluid.
Bad news is that the trans fluid was GRAY with a red tinge towards the end of fluid removal. I"m preparing to remove the transmission soon. So, I assume my conveter is no good as I do not know any reasonable way to flush it. That's ok, I have my stock converter, but this converter set me back 600...is there anyway to salvage this converter? Also, when rebuilding the 4l60 E, where can I find the proper information to find clearance tolerances for the bushings and bearings? Best rebuild kit?
Thanks everyone :)
Quickstop [UK]
Combating adversyty.
The same places that restall converters will flush them for the same price, maybe less. ~$200 was what I was quoted.
www.700r4l60e.com has good bits, as does bulk part.com
There is a really good book on Amazon for rebuilding the 4l60 (by Cliff Ruggles) that takes you through it.
I rebuilt a trans earlier this year. It wasn't too bad.
Disassemble it, find where the problem is and work from there. You may not need much. Tools are the most important bit and a clean place to work with lots of photos to help you reassemble.
atkonkler
Is this your bush?
700r4 do it yourself it's pretty primitive, 4l60e bring it to someone who does them... Buy any kits from monster transmissions @ eatmyshift.com
atkonkler
Is this your bush?
I'm just a noob...don't you remember Dave? As per gm it's a 4l60/700r4 coded either mx0 or md8... :'( A good friend of mine is ASE man of the century with every cert there is I do believe and watched him build just about every trans in every make and model. I think you guys should meet sometime and go bowling with beers. But I still like you Dave... Have a good day!.
Cheers!
Aaron
Logan
I've heard that ticking more than once and on more than one GM truck. Its the front pump.
Osmosis
I"ve been taking my time...obviously :( Today, I removed the drive shaft and prop shaft and cross members. Next week, the work continues. I will keep posting and I hope to find the problems...I just pray it's only the pump ???? With all that gray matter out of pan, I think I have more problems than the pump. Either way, they will be fixed soon enough!
Thanks for the info guys! :tup:
IGottaSy
You got the right attitude needed to owning these trucks:tup:
If I had known how "unique" and "sensitive" they were, I'd have spent my $ on a good old reliable pre-war truck(Ford) instead and done the usual late GM drivetrain swap on it for peace of mind. I'm not a quitter and here I be.
If I may, I'd like to recommend the shop who built my truck's 'mission. They are in Texas.
They are called Phoenix Transmission. What You would get:
1. Experience
2. Attention to detail
3. Great combination of parts at your power level
4. A NEW converter
5. A quick turn around
6. And last but not least... 50K/3 yr warranty!!!
Icing on the cake? Their warranty doesn't begin until your "baby" is on the road!
All this for under $1800 with shipping, probably.
:tup::tup:
I dropped off mine and went to pick it up since they are only 4 hrs away.
Osmosis
I appreciate the offer, however, I always do my own work, that way I know it was done right. I worked at a very reputable hot rod shop all through highschool. I assembled stock to high HP engines in the summer. I"m sure I can figure out how to rebuild the transmission with a good manual and maybe a few youtube videos....I'll rely upon the manual as that is how I was taught to work on automotive stuff ;)
Logan
And when you disassembled the pump on your bench, what did you find? What was the cause of the ticking?
I've only heard 'ticking' in one 4L60. It wouldn't move in D4, but it would in D1,D2,D3 and Reverse. I didn't work on this trans, so I didn't see the actual problem with my own eyes. But the lack of Forward in D4, but OK in the other ranges is classic "broken forward sprag clutch". so I associated the 'tick' in this trans with a broken sprag.
I won't make an association with a noise I haven't personally investigated with either the sprag or the pump, but I am curious as to what in the pump would 'tick', and how. I've heard pumps whine from air in the pressure regulator, but I don't see how a single vane would cause a tick, or how the sound would be generated. Much less how a noisy pump could cause loss of drive unless it was totally demolished from improper torque converter installation.
One transmission was due to improper Torque Converter install and it ticked from then on until it died approximately 100 miles later. Transmission shop said front pump
Two more transmissions developed a tick that would increase and decrease with throttle but came from TC area. Both transmissions were diagnosed as pump failures. Now, there may have been other issues as well but I do not work on transmissions so I could only go off of what was told to me. I was just throwing my experience in since it seemed reliable based upon what I have dealt with. That is not to say I am not dead wrong though.
Osmosis
When I pulled the pan, my trans fluid was extremely gray. The last quart I was finally able to see RED trans fluid. Would a bad pump cause this much discolation? I fear there may be more problems than a bad pump, just not sure???
My ty ran fine up till the one day I felt her slip from 1-2. I pulled my foot out of her and drove home a aprox 3 blocks. Since that day, I would pull her out of the garage 20 feet, wash her and park her in the garage. Then after 4 months of sitting and doing this, she decided not to move at all. I heard a loud screaching for about 2 minutes max, then she would not move. I hope it's just the pump......we will see soon:crazyeye: I just pulled the transfer case and so I hope to pull the trans sometime this week.
