TY not running right Help!!
autoaddictions
Well as some of you guys know i cracked on of my heads by leaning it out on meth last season. I bought a new head and swaped out the cracked on. After i put it back together it ran ok till i started making some boost(3psi) then sputterd and run like shit. However it will idle ok. It was getting cold out so i threw it in the garage for the winter. Well winters over so i started it up to bring it to my shop and it runs like shit still. I pulled the upper IC pipe off the ATA intercooler to throttle body and noticed antifreeze inside!! Now im wondering if i have a bigger problem caused by leaning it out. I didnt change the Cometic head gasket on the drivers side since the pass side head was the cracked one, I did preform a compression test on both sides after i swaped the cracked pass side head out. It was perfect on both sides and very even from one to the next. Now im stumped??? Will a leak down test show me if i have a lifted head gasket on the drivers side. Ive never heard of coolant in the intake before because of a blown head gasket!! Have you? Of corse it dosent over heat or puke coolant into the overflow either. Theres no coolant in the oil pan and it dont smoke when running of smell sweet. Im lost here any good ideas out there????????????????????????????
Raist103
Re: TY not running right Help!!
same type of thing happened to a gn i had. i thought it was one head gasket but it was both. same thing happened to a friends stage 2 car he had 2 cracked heads
Ry368
one mile = 5280 feet
Now im wondering if i have a bigger problem caused by leaning it out. I didnt change the Cometic head gasket on the drivers side since the pass side head was the cracked one, I did preform a compression test on both sides after i swaped the cracked pass side head out. It was perfect on both sides and very even from one to the next. Now im stumped??? Will a leak down test show me if i have a lifted head gasket on the drivers side. Ive never heard of coolant in the intake before because of a blown head gasket!! Have you? Of corse it dosent over heat or puke coolant into the overflow either. Theres no coolant in the oil pan and it dont smoke when running of smell sweet. Im lost here any good ideas out there????????????????????????????[/QUOTE]
Yes...a leak down test will tell you if you have a bad cylinder from either a head gasket and or a broken ring, bad valve job. A leak down is considered the ultimate test for engine cylinders!
syclownz
Are you running head studs or bolts??? Studs are hard to prevent from leaking. I believe you are suppose to use a red lock tite if I remember correctly. Do a search to make sure.
ViciousV6
400HP/550FTLB
Hey Frank,
Just got my Beater fixed tonight. Still gotta work on the trans shifts really hard when cold. Tranny guy gonna look at it next week but i just had dist issues with it moving but that is all fixed. What a Bitch but its done and the truck flys.
Do a Leakdown. This will eliminate any ring or piston issues, but don't rule out a crack in the head somewhere seeping into the intake passage, that was one problem Ed had on his truck.
Also make sure nothing leaking @ intake to Head gasket.
Ralph
jwaller
Evil Genius/SyTy Guru
might have cracked the block. I've had this happen several times running them hard. middle of the #4 cly about half way down.
autoaddictions
Well the verdict is::: After a leak down test motor seems to be fine. I changed my plugs and wires fixed a small fuel line leak and my truck still ran like shit. Sputtering to the point of a stall when load is applied. heres the weird part im useing a Razor Alky kit and when i turn power on to the ALKY ite runs better if i turn it off it stalls and sputters some more. Keep and mind here the alky tank is bone dry. I figure its got to have somthing to do with the alky kit. The only wire hooked up to the kit that i fugure could cause havoc is the map sensor signal wire. I cut the wire and poof problem gone!! Now i only ran 15 pounds of boost on my test runs but the engine seemed to sing like a bird. I guess i have a bad alky control box or a bad ground under the dash. Ill have to get into that issue later but for now the engine worries are over.
Now if you read my first post i mentioned that there was coolant in the T-body and intercooler pipes!!! I think i figured that one out too....
When i cracked the head last season it over heated and spued coolant all over the place. Since im running a open turbo it must off sucked the coolant spray into the turbo and forced it into the intake and intercooler. When i replaced the cracked head i only removed the upper ic pipe from the front mount. So im guessing that the coolant was laying in the bottom of the intercooler the hole time. I removed the intercooler and drained 8oz of water from it.
Well it runs good now i just need to iron out the Alky kit issue and im off to the races.
