whiteTy1214
Could use some ideas, ty is stalling or tring to die while driving.
Has died several times in park or in gear at idle, while driving drops off more than 500 rpm.
fuel psi looks good, have set check engine light before. try to flash code just 12. :rant:
I know my ecm has a broken mounting tab, wonder if it looses connection at times.
I ordered a new reman ecm from autozone, hope that might fix my concern.
Any other ideas?
Also i blew out my atr ss header on the passenger side again, had it welded to fix it last time, lasted like 6k miles...
Also noticed quite a bit of vibration in park reving it up over 2500 rpm... I have solid motor mounts but i think the vibration is excessive. feel it while driving highway and freeway speeds. neutral test during vibration speeds it is gone, only in gear or reving in park.
so dont think it is drivetrain. thanks for any help. have a good one guys. thanks for looking!:tup:
Any other ideas?
