Ty rear Defroster harness
2500avalanche
Well-known member
I checked rock auto, and it looks like the incorrect harness. I am looking for the part that connects to the strut and goes to the passenger side (it is a ground) Previous owner cut it.
Anyone have one (even cut, I will connect it) or the correct part #?
atkonkler
Is this your bush?
Re: Ty rear Defroster harness
I know it's cold outside bit I'd make a couple of calls to the yards and find some s-10 blazers it can't be that much different from a Ty other that drivetrain, engine and Tranny. If you want ill try to get to a yard and look for you just let me know what I need to tear out .
jaystcb
Sy 0902, 92Ty 0909
I sent you a PM. But figured that I would answer this post anyway.
A junk yard is always the best place to find some of the plastic housing for the defroster plug at the rear hatch. But... Good luck. they are few and far between. If you don't care about exact replacement. A 2nd gen blazer will have almost the same connector. The difference is that a 2nd gen's housing is a little thinner but will work with the terminal. You will have to buy some new terminals.
also
If you don't care about an exact replacement housing you can Buy From NAPA
P/N 787150 (Chrysler alternator harness) comes with 2 connectors pre-wired.Price is around $3.50
They look almost identical to the the stock plug except they have a plastic hump for a lock clip. It is very easy to file it off for a stock look.
Like I said. You Will have to Buy new connectors. I found some sold by.
JT&T p/n 1200F (16-14 AWG .250 Tab, Split Female) comes in a 15 pack for around $7 bucks.
Hope this helps.
