Ty wheels sticking out
93 Ty
Hi, just wondering if that is normal. My fronts sticks out and not align with the rear. It's obvious. Is this normal. The truck is lowered. It has stock chrome rims. It goes as far out as almost to the cladding (fender). THanks, Steve
Ty0279
Historically Significant
SyTy wheels are front and rear specific. Pull your wheels and make sure they aren't switched.
wrx2typhoon
Its probably normal, i noticed my drivers rear sticks out farther than the passenger rear as well.
It wasnt evident until i lowered it. It was like that stock , i switched back just to see. You just notice it more once everything is close to the tire.
All my cladding fits perfect so thats a non issue. I have noticed this on alot of tys.
GM TURBO
Sell Out
It isn't normal...
If the wheels are in the right position and they stick out - you have some structural issues - or it's something really really odd.
I'd say a tweaked frame.
Junior1
NASTE Member
My thoughts are like Ty0279, check to make sure the rims are on correctly. If fronts and rears are swapped they will stick out too far in the front and be too far in, in the rear
However, if the rims are correct and it is only the rear, I would check to see if it happened when it was lowered. If you used lowering blocks or swapped the springs there is a good chance that the rearend may have moved or gotten misaligned when tightening up the U bolts. That in turn would make the rear tires stick out to one side and seem too far in on the other. Pull the rear wheels and take some measurements to make sure the rear is centered under the body. If it started off a little off center, it would be more pronounced now since it is lowered.
93 Ty
Guys, thanks for the replies. I will get the wheels checked out to see if they are switched (I did get them balanced not too long ago). You guys are talking about the rear but my fronts sticks out (noticible, a good 1-2 inches). Thanks, Steve
Junior1
NASTE Member
If thats the case then I would bet its definately that the wheels are switched. Just swap them and you should be good to go...
SY2932
Administrator
Pull your center caps off and it will be plain as day, as they have "front" and "rear" cast into the aluminum in between the lug nuts... Sounds like they rotated the tires for you in the process and didn't remove the tires like you have to with these trucks.
wrx2typhoon
Well mine is like 3/8" different and i know it has never had any damage done to it. I still say its possible that some of these trucks are like that :-? .
I have seen way to many Tys for them all to be frame bent trucks.Unless they bend from daily driving or hard launches .I'd side more with a misaligned body from initial assembly.Ive never been a fan of gm build quality anyhow. So maybe its not "normal" But common.
syclonekid43
if your talking about the fronts stick out more than the rears. thats just the way the trucks are set up. seeing it has a 4x4(awd) stance. i notice this on a lot of 4x4 trucks. but if the right side sticks out more than the left then there is a issue problem. i know alot of people including myself. that have lowered 4x4/awd and for some reason one of the front wheels sticks out more than the other on certain trucks.
