Ty with a GN turbo
akwilks
Mr. Keith
My Ty came with a larger turbo and the hose thats used on it seems a bit worn....What type of hose should I use as a replacement? Initially, I had to get my rpms up a bit to get good boost (13-15lbs) but playing with the hose the truck gets boost faster...I have an ext wg w/ boost valve and she feels stronger but she pings so now I have my boost set at about 10lbs and I stay off it...alky inj is in my future
Arn
93 Typhoon #1269
SeattleSy#1255
Category 5 Conservative
Re: Ty with a GN turbo
What hose? Vacuum hose i'm assuming?
Should replace all the vacuum hoses in the truck anyway, they are way to old, crack, leak, and could be part of your lag problem.
don't throw alki on it to get it to stop pinging....find out the source of the problem. I'd check the chip first and do a tune up with the correct parts.
akwilks
Mr. Keith
The hose I was referring to is the turbo outlet to IC inlet hose. I guess I got a bit distracted when I decided to go to the store and back to find my passenger front tire has a flat....It must of happened right as I pulled up to my house but nonetheless a big distraction....My Ty is beginning to cost me a fortune.....
Arn
93 Typhoon #1269
QUICK STORM
B.A.M.F. BMW Tech
Arn
93 Typhoon #1269
you gotta a vacuum leak, fix it.
