typewriter sound coming from tb?
AlaskaTy
So this is wierd, I put a paperclip between my A and B ports on the ALDL to run my ic pump to top off the fluid level. Well, that didn't run my pump, but I was getting a weird typewriter sound coming from around my tb. The key was on, but the truck wasn't started, and it had something to do with the paperclip in the ALDL....this normal?
ItsMyTy
Life is beter at 25 PSI
that's the IAC valve moving around... mine does it randomly, too. sometimes just sitting with the key on, engine off.
SY756
Sounds like your pump or relay may be bad. I bet that sound was the pump relay located on the firewall just above the distributor. I'm pretty sure it's one or the other.
AlaskaTy
That's good to hear, I was about to kick the crap out of a garbage can if I had to fix another problem!
