Typhoon Duel fuel pump system
s_blazin
ATR DUEL INTANK FUEL PUMP SETUP, FOR TYPHOON ONLY.
TY fuel senders are different than sy senders so i can't use this on my SY.
This is used to run 2 pumps inside the stock tank when making over 400whp
Comes with ty fuel sender assembly, hot wire wiring conversion harness, and 1 walbro 255lph hp fuel pump. unfortunatley i dropped the other pump and cracked the inlet side, so it's probably no good anymore. so for this to be complete ready to drop in your tank, you will need another pump to replace the damaged one. i will include the damaged one just in case someone feels it is still useable.
$400 OBO
fyi RPM sells their kit for 700, and this is only slightly used and still in working order, aside from the dummy move i made and damaged the one pump
comes with installation and useage instructions
call, text or post here
503 851 3385
Logan
Re: Typhoon Duel fuel pump system
If gobabygo does not take this I will call second in line for the right price.
Logan
If the sale doesn't pan out, pm me and you have a buyer. Thanks.
s_blazin
sorry i didn't update this sooner. sold to gobabygo. thank you for all the interest
