Windedv6
Ty n 10s
Now that the frame is back from the power coater, it's time for assembly. Here are the first of the assembly pics...
Front suspension and steering rack assembled...
Billet frame covers for end caps. Will be able to run additional wires inside frame if needed...
Exit for power cable that will be run inside the frame. This comes out by the firewall and starter...
Billet steering rack mounts...
Frame mounted trans cooler mounted...
Anti-roll bar installed through frame. Brackets were installed on frame when anti-roll bar is not attached to rearend housing (better ride for the street)...
Polished 10 gal fuel cell installed. This will use the stock Ty fill tube. Also battery is in it's place...
Rear frame end cap. This is where the power wire comes out of the frame. Also the positive and negative charging posts can easily be accessd. A copper fabbed plate is used to connect the negative post to the frame...
Spring loaded latch to release the receiver for the hide-a-way parachute bracket. This receiver is located behind the fold-down license plate...
Rearend assembled. This is Moser's heaviest duty aluminum center section with gun drilled axles and star hubs. The "Fab 9" housing from ChassisWorks is made of chromoly...
That is all for this last week...hope to do more this week. Will keep posting new pics as assembly continues...
John
John
