typical BS3 installation cost???
I have a friends truck I'll be doing the same standalone install on soon. His trucks wiring and under hood is very clean as mine was. This will aid in cutting down time cleaning up and orginizing/eliminating unused wiring. I will spend as much time as it takes to get the install done clean/correct. I took a lot of notes and labeled the trucks side wiring, that consumes time but should help me on my next install. I have no price in mind for my friends Ty, although I plan on having it done in two days.
You will need to purchase the small HEI to large HEI adapter for the ign module. EFI connection sells them. Be careful as one of the two I ordered was pin'd backwards, I still need to re pin this before I forget. At the time of my install I swapped it with the other which was correct. That mistake made a fun no spark diagnosis after a long awaited first start
