ok this is the up date on my promblems
I just did a lower intake gasket today
and put new injectors in
changed the plugs too
so far changed
o2
iac
tps
tested the egr - ok
cap
rotor
wires
turned waste gate down to stop over boost
top end cleaner
all intake seals
throttle body seals
pvc valves
compression test - ok
the stall when putting in gear is gone
the popping in the exhaust is there once in a while at idle
the top end is better but here alittle knock just before it shifts when getting on it
but it still has a rough idle, breacks up to 1500 rpm
even when driving
need help
any ideals? on what to do
so far changed
o2
iac
tps
tested the egr - ok
cap
rotor
wires
top end cleaner
all intake seals
throttle body seals
pvc valves
even when driving
need help
