Ugh... found hole in motor
NateP
Money Pit Member
Popped the lower intake off today and found a nice hole in the rear passenger side corner of the block...
son of a...
Looks like ill be needing a new block and instead of screwing around I want some solid advice. What are my options for replacing the block, and getting it to mid 11's with good street driveability. To save the cash for this im not planning on having it on the road till mid summer, so price really isnt an issue on parts.
I also need a lower intake manifold thanks to one of my friends any aftermarket options here? price?
Partying right now since I just turned 23... great B-Day present :evil:
TIA for the advice
Nate
One pissed off guy with broken vehicles
what is wrong with intake? I imagine it will be cheaper for you to have it fixed, welded, etc.
No easy aftermarket options.
Stockers demand a high price also.
warmpancakes
Go buy a 1992 s-series 4.3, same block swap your mains over have it line bored, you also get l-35s in the deal also.If you arent far from Michigan My buddy has one out of a 1993 blazer thats noisy for 200.00 complete. or less
Ken
Falco
Sorry to hear it. If price is not an issue, but a complete engine from Mike Lee at RPM or from Jerry. I haven't check their prices lately, but $5k should be enough for a strong build, which can take you into the 11's with the proper turbo.
BTW, what happend with your block?
Later,
Sy769
Ken
L-35's came in 94-95 with the Vortecs starting in 96.
be very careful on stock block selection as core shift is common. A full street/strip prep of the stock block can get expensive fast. I think my next build will use a bowtie block if possible just to avoid the hassle of finding a good casting. Four of the blocks I tried had enough core shift a .030 bore would have resulted in thin spots in some of the cylinders.
NateP
Money Pit Member
knuckle head buddy was prying away on it and had missed a bolt... cracked around the 4th bolt in on the passenger side... I now have two 1" pieces... and I'm not thinking they can be fixed, but please tell me if im wrong... ill post pictures Monday.
InvisiBill
Sy769 said:
Ken
L35's came as early as 92. See the Sonoma GT for details. =) However, not all 4.3's were L35s, as my 93 S-10 has the TBI LB4. The L35 is the "high output" CPI with W VIN code.
MikeRenz
not stock
Sy769
Falco said:
Is there any straigth forward way to check a block for core shift?
Later,
A careful sonic check is one way. You want to make sure cylinder thickness will be adequate around the perimeter of the bore after the cylinder is resized .
That is pretty harsh break. I would make sure you don't invite He-Man over to help on the truck anymore.
I was thinking crack, more than whole sections missing.
You will probably spend as much on machining, and welding than it is worth.
If you do find a used one, I would be interested getting it off your hands though (cheap to free), as it would give me some good practice on syty intakes and my welder.
NateP
Money Pit Member
thanks for the info.. not sure what im going to do with it right now, might let someone give it a shot. Looks like ill be looking for a new lower intake though, unless someone comes up with a aftermarket one
Nate
