Ultimate boost problems
92 Ty 1173
I just installed an ultimate for a stock truck. I had an ATR pitbull and was running a bleeder valve for boost control. Now with the ultimate I put the lines back on for the stock wastegate solinoid and now I am have boost issues.
1- My pillar boost gauge only reads 10psi in the T1-15 setting.?? Wastegate rod adjustment?
2- The boost is slow to build. In a higher setting the boost will come to @ 10 psi and hold for a second the shoot up to the set amount.??
3- I had the check engine light come on the first run. I did the check engine light trick and got a 42 and a 45. My Chilton book says the 42 is an open or grounded circut.? And the 45 is a rich exhaust. Are these common for the ultimate or is there another problem?
4- I know I will have boost control problem because I gutted my cat and heve the common cone filter on the intake. One thing for sure with that set-up the turbo is very quick to spool.
Any help of suggetions would be greatly appreciated. Thanks Jason.
denny
Re: Ultimate boost problems
Maybe your wastegate solinoid is not working.
I have a vew of them , if you need one.
92 Ty 1173
I know the stock WG sucks but what options do I have with a stock turbo? Anyone on the codes or other suggestions on the boost issue. I really need help on this one. The chip is worthless with these problems.
SeattleSy#1255
Category 5 Conservative
you have the option of going with an external WG with your boost valve or you can port the stocker for better control. It may also just be sticking on ya, causing problems.
Flyin Ryan
hated cuz he drives fords
Did you reseat the ecm b fuse? possibly it's got a stored code that isn't really a problem anymore? Just a suggestion
92 Ty 1173
I pulled the ECM fuse when I put the chip in. There were no codes prior to the install. What kind of external WG? How do you go about adjusting the actuator rod? Also what is the best way to port the stock WG? Is a BOV really benificial to these trucks? It would deem that due to the auto trans that boost loss is nill and the only benefit is the loss of turbo surge during a throttle lift.
92 Ty 1173
Thanks a bunch for the info. Anyone got some helpful advice for the rod adjustment.
Flyin Ryan
The stock adjustment is 7/8th of the wastegate pin showing through the rod atachment I believe don't truely remember it's been a while since i've messed with mine. If you shorten the rod it'll increase boost, lenghten rod decreases boost.
92 Ty 1173
Good deal. I'll get it adjusted and see if that helps. Where can I get an external WG. Was on turbotime and detoit turbo and the have the tial wg but they don't look like the one from the SyTy archives page. All this stuff is kinda foreign to me.
SY-1193
Jason,
First: Check the wastegate adjustment as discribed by Boostedpimp.
Second: Check your hose (or) tube from the turbo to intercooler for leaks and also the intercooler to throttle body hose. Make sure your clamps are tight. If there is a leak in either of these hoses you may experience boost loss. Another source of a leak although not as likely may be the gasket between the Throttle Body and Upper Intake (or) the gasket between the Upper/Lower Intakes.
- remember to clear all your computer codes and try again.
As far as the codes see if they pop up again. (This sounds like a separate problem) If so ~ maybe your O2 sensor is slow or needs replacing. (Code 45)
HTH
92 Ty 1173
Where can I get an external WG and what size? Found some place in Australia that has 38mm to 50mm WG's for $190 to $290. I guess thats what I need. I will be pulling the motor so now is the time to do any fab work. Also I had the turbo off this summer and the local shop inspected it and said it is fine. The actuator was operating just fine also so I think it's something else.
Flyin Ryan
The wastegate shown on those instructions is the ITS mini gate I believe. You can pick them up on here from time to time or get them from Mike at http://www.raceprovenmotors.com/cart/index.php?cPath=27_113
If your using a stock turbo and your gonna be yanking it and will not be going the extranl wg route. Then get your stock wastegate ported to handle the increased exhaust flow from not having the cat installed.
Mephisto
These trucks are cursed
how well does the truck run with the stock chip and the 2bar MAP?
also try reseating the ultimate... the first time i put it in, i got the o2 rich code. I must have reseated the chip 15 times before it worked right, tempermental shit i guess.
second, you could run T3-22 and still only get 10psi if your wastegate is not adjusted properly. dicking with the wastegate rod is not that difficult, its just a PITA to get the wheel well outta there if you havent done it before (bolts like to stick when they havent been moved in 15 years). all you gotta do is remove the cotter pin, adjust the rod to your desired length, put it back on, and go test. if youre still not making over 10psi, well.... then you got some solenoid issues to look into. if you dont have an aftermarket boost gauge, i would look into getting one of those first, as the stockers are as useless as hen shit on a pump handle.
bottom line. external gate with boost controller=rock solid boost.
if youre going to stay moderately stock, go with the ITS mini-gate from RPM or favorite vendor of your choice.
Cheers
92 Ty 1173
Cheers
I had an ATR pitbull chip with a bleeder valve controller in before and it ran good. Had spikes due to the lack of cat internals. When I yank the motor I'm gonna put a 3" pipe threw it and I have a 3" DP to put on it. So I need to get the boost under control. My bleeder will work with the mini gate?? If so that sounds like the way to go. I'll have to figure out how to mark it for different settings. And yes I so have a boost gauge, VDO. I wanna replace it with a Stewart Warner gauge. I have them in my Dodge and I love them. I'll try the other stuff to make sure it is in right. Thanks again.
92 Ty 1173
If the T-1 timing setting is stockish is the T-2 and T-3 advanced or retarded?
92 Ty 1173
Ok I reset my ECM and ran the truck and upon start-up it immediately threw the code 45 for rich fueling. WTF is going on here. I didn't have a problem before the ultimate. Now I'm haveing all kinds of problems, rich fuel, overboost, lack of boost. At least the 42 code didn't come up this time. I'm going to check the chip to make sure it is in right. I would think so or the truck wouldn't run, right?? If the MAP is bad will the truck even run right? It is running rich so I am alittle suspicious of the MAP. The guy I got it from said it is a 3 bar. If it's a 2 bar it won't runn right at all will it???
Flyin Ryan
Check the ECM.. make sure the cables are all tight.. possibly swap in the stock chip/reset ecm then see if any codes appear again if you stil have it. Im sure there's a way to check if your 02 sensor is functioning correctly with a meter but don't remember at all.
Pull the Map sensor and compare it with 3bar part number.. I have an older one so mine prob won't help but here it is
92 Ty 1173
Ok I reseated the ultimate and still got the rich code. So I took it out and put the stocker back in. Nothing, no 45 code no sputter, no boost hesitation, nothing. WTF is going on. Why would the Ultimate be throwing a rich code? The worst part is despite the open loop system it is throwing the code within a minute of start up. If I let it warm up it will throw the code, I don't even have to drive it. My 3 bar that came with the chip has a part # of 12223861, same as yours Boostedpimp. The only good thing is that I got my C-5 wheels and new tires mounted and balanced, too bad the truck won't run right. Does anyone know what the Ultimate will do if I install my ATR pit bull chip with it instead of the stocker??? Everyone says not to T off the line for the MAP where/ how can I reroute the vaccum line to be sure eveything is supplied? What is the round thingy mounted on the back of the MAP and can it be eliminated?? Sorry for all the Q's but this problem is getting old quick. Thanks Jason.
