Ultimate chip doesn't fit???
RSpengler
Ghetto Fab Specialist.
I bought an ultimate chip (50# / stock) and control box with key and everything off of ebay, but when I went to stick the chip in the ECM, I found that the little tabs that hold down the chip are completely in the way of the Ultimate chip, with no possible way of locking it down or even getting it to seat??? Anyone else have this problem?
Thanks,
Rob
Loeryder
Re: Ultimate chip doesn't fit???
You have to trim the hold downs.
The case will hold the unit in place.
Be sure to cut a slot on the edge of the case to allow room for the ribbon cable to not be pinched.
STG instructions said:
Installation of hardware: Remove stock memcal (chip) from ECM. Carefully plug the memcal into the multichip piggyback prom carrier with the key (tab) on the MEMCAL sliding into the slot cut into the piggyback carrier circuit board. It is recommending that you trim the left memcal retaining clip (the one closest to the top of the ECM). The idea is to trim off enough from the edge as to not crimp the ribbon cable when the carrier is installed into the ECM and to allow the carrier to seat fully into the connector. It has been noted that it is possible in some ECM’s to install the chip completely without trimming this clip, but I personally recommend trimming. The ECM cover will prevent the memcal/carrier from working loose. Plug the carrier into the connector in the ECM from where you removed the memcal. The memcal will be toward the side of the ECM where the wiring harness mates. If you have the carrier in properly, the two retaining clips will close as you push the carrier into the connector.
