viperman5
After installing the Ultimate chip, the truck would lag more and underboost to 10psi in 1st gear then creep up in 2nd and 3rd gear to whatever I had the chip set at. Based on the chip instructions, it said to adjust the wastegate.
I adjusted the wastegate about 3 turns and nothing happened. Using the search function and reading other people’s issues, I thought I might have a bad catalytic converter clogging up the exhaust. To test this, I removed the vacuum line from the wastegate solenoid and had NO problems making 20psi boost with very little throttle. I am guessing my catalytic converter is not bad. Am I wrong?
I then put about 6 or 7 turns in the wastegate and now 1st gear holds 14psi and 2nd and 3rd gear creep 1-3psi past the setting on the chip.
Before installing the chip I have changed the vacuum lines around the wastegate solenoid.
What should be my next steps? I appreciate any help.
