91blazins10
Well after lurking around on the boards for a while this is the first time I couldnt find a answer to my problems, I bought jeremys typhoon back in october aka "jeremysyty" on here. Had the stock chip in it and ran fine, and recently on ebay I bought the ultimate chip, put it in adjusted the base fuel pressure to 50psi at idle. And it started right up no problems. I then decided to log a few runs on datamaster at 18psi, it ran great but I noticed when i came to a stop at idle the rpms would flutter and it would almost die so I would have to give to it gas to keep it going. After some more digging around I noticed that with the stock t1-15 setting it runs fine, but when I switch over to any other setting it starts acting up instanlty, but only at idle, its like when I switch it theres a vacuum leak all of a sudden. I have a brand new IAC in there as well so that shouldnt be a issue. Could this be a issue with the egr being disabled in the other settings? :dunno:
