Ultimate chip
D
DOUG
Guest
When using the Ultimate chip which setting works better overall ?
AXXE
Everyone has different results. It depends on how knock resistant your truck is, what octane fuel you use, ambient temp, supporting mods, etc. Hook up Datamaster and find out what's best for you. I run T1-18 on 93 octane all of the time. When it's cold out, I run T2-18.
kwick6
every truck is different.. hopefully you have a scantool.... that should tell you what you want to know.
JustBeachin
Plays well with others
Around town I use SEC and T1-15.
At the track I use 3-20, but that's using 112 octane.......Do all the basic performance mods, Fuel pump, fuel filter, plugs, wires, cap, rotor, get datamaster, or diacom before you buy the chip.
Sy769
Get Datamaster and learn how to use it before you buy a Ultimate.
You can't just try a setting and see how it runs. Doesn't work that way. You need to know what each setting is and when you should advance to it.
Start with T116 as EGR is disabled in that program and will help keep the MATs down.
93 octane minimum for that program.
You need someone watching the laptop for knock and lean conditions the first time you run any new program no matter whose it is.
--SyTy Jim--
GAST Member
::protestno:: ::protestno:: ::protestno:: ::protestno::
::steamer: ::steamer: ::steamer: ::steamer: ::steamer:
Am I the only one??
Jimmy
MyTyphoon1993
Of coase it will fit a suburban, but the mod that I think you need is a Flux capacitor and get that hovercraft conversion done.
kwick6
obsessedw/f-bodies said:
dose that mean that i have to make my exterior body stainless steel? cuz if thats the case then the suburban won't b able to get out of its own way.
no better make it aluminum foil, so you can tear off a piece every time you need a new crack pipe.
SYO237
SyTy Registry
obssessed...
get the fuck off this board if you think your going to be a smartass like this.
im sick and tired of going to the board and seeing your pointless posts strewn all over the place.
You either straighten your attitude and keep your mouth shut with your comments to yourself or I will have your IP banned permanently.
Think Im playing? Try me bud..... keep on posting.
SYO237
SyTy Registry
Darn. Im gonna miss ya obssessed.
Let us know how finboy is doing... oh wait, you cant...
YOUR BANNED!
:eek: :fist: :drinking: 0X
