Ultimate question
VinPecora
I have pit bull chip now and planning on buying a ultimate chip,but.....I just installed a 20g turbo and I have a atr boost bleeder valve. Now my question is The valve fully closed im running 18psi?? before on the stock turbo fully closed it was like 7 psi. do i have to disconnect my boost valve and hook up the factory unit again with the install of the ultimate? shoudl i adjust the wastegate arm and set it to 15 so that the ultimate can control boost?? What do you guys recoomend and how to do it?
spooldup
Super Member
you can let it control boost but i would rather see a quality boost controller doing that job. Just leave the plug disconnected to the factory solenoid. O also get a 3 bar map sensor.
spooldup
Super Member
It controls the stock boost solenoid. If you use an aftermarket boost controller you won't need it. Besides it doesn't work very well. I am running a profec b in both the supra and typhoon and they both work flawlessly. The spool is faster as well.
MjP
Banned
valve must be leaking at closed position...
either that or you have wastegate problems....
my 20g used to creep on me quite a bit.. to like 20psi...
dunno why, mabye wastegate is too small
ZavzTy547
Senior Member
Did your new 20g come with a new wastegate actuator (rod)? If that's the case it probably has a stiffer spring in it, which will give you a higher base boost than stock (at the same boost valve setting). Sounds like you just need to adjust the rod to base boost, which is 10 psi, with the selonoid disconnected.
I would do what spoolup said and get a 3 bar but I wouldn't go with the profec just yet. The ultimate also has the features to change boost settings and should be able to control boost with the seloinoid hooked up (with the exception of 1-2 PSI flucuation" depending on if your wastgate was ported etc, etc...) as long as you properly adjust the actuator.
Test this out using the ultimate, if your not getting descent boost control then try the profec or just continue to use the bleeder.
VinPecora
Re: Ultimate question
ok one more time here....I disconnect my bleeder valve and adjust the wastegate bar to 10 psi and then hook up the solinoid again.....I feel like if i disconnect the valve the boost it going to spike through the roof. I just want to adjust the bar to stock and let the ultimate do the work with the stock soliniod. please walk me through this guys. Thanks Vin
