Under boosting
QUIKSUV
Has anyone else had this problem with the Ultimate? I have searched and found more threads talking about low boost with this chip. Some can fix it, most can't. Are guys using the chip with a separate boost controller? I bought the Ultimate based on recomendations from this site. I think it has definite advantages so I do not want to abandon it right away. So who can help with this problem? How does the boost control work in this ecu? Looks like w/g duty vs rpm with a slow correction. No learning or long term integral correction. Can I change the code myself if I have the right tools? I think I can fix it if I know how it works.
QUIKSUV said:
Any progress on this problem?
Right now I am concentrating on other issues. My WOT voltage is only at 12.4 volts and I have stuble at idle. I am planning on having my injectors cleaned and replace my intake manifold. I am hoping that will fix my idle and maybe this is all related. My truck seems to build as much boost in first with the stock chip (and its 12psi limit)
ghettosled
SYTY SUPERSTORE
i'm back in town and will be assisting people with their chips problems.
Gary, do you have a V7 or V6 chip? with an upgraded turbo and IC you should have a V6 chip.
email me privately to confirm if you wish.
FLSY2730
I hear more good things about the ultimate chips than bad , with any product in the world there will be some problems , how many ultimate chips are out in circulation, 400-500, and 4-5 people are having problems, seems like a proven product to me.
QUIKSUV
Interesting comment.
Do you have an Ultimate on your truck? How is it working for you? What were the improvements you got with it? (Not a poke, I'm serious)
How many chips are really out there? Do you really know or are you guessing?
There are more than 4 or 5 of us out there with problems. Looks like the Ultimate works best on stock trucks. I have too many mods or other factors so it doesn't work for me. OK, time to move on to other mods that can work.
Just checking to see if you are qualified to make such a statement.
FLSY2730
Works fine for me, i have no idea how many chips are out there, i bet it is more than 30 that someone else mentioned, they been making them for how many years, maybe its not 400-500 but it has got to be up there.
Hell there were what 7000 trucks made total, and almost 2000 members on this board , and not many chip options so i bet there are alot of ultimates floating around.
ghettosled
SYTY SUPERSTORE
I started selling the chips for Todd and BG well after the intro of the 3 bar chips. I have personally sold over 100 of them, and have had maybe 3-5 people want to send them back.
Others either got a bad prom which was fixed, or just overlooked something during the install, and was eventually fixed. So I would say it is safe to say well over 200 people are satisfied with the ultimate chips. Many of those people being some of the more well respected gurus in the syty world and have had some of the quicker trucks.
Maybe if we dissabled the knock retard feature more people would be happy :) seemed to work for Jim Bell for quiet some time
TurboTony
Thats a very good point Mike...
All of you who are experiencing w/g duty cycles that suddenly reduce and lower the boost, do you note any knock counts a frame or two before this happens?
From what I understand the Ultimate has a much quicker rate of timing and boost reduction when knock is sensed. That may just be what you are chasing.
HTH
Tony
QUIKSUV
Mike,
Good to know you have lots of satisfied Ultimate customers. Wish I was one of them.
Turbo Tony,
My DM runs show no knock retard for the whole run. Knock count is constant. Any other ideas?
I think its the upgraded turbo I am running. The required w/g duty will be different as the w/g flow is better. Open the w/g more and you have less boost. Stock turbo must overboost easy with barely adequate w/g and needs to be opened more to not overshoot. W/g cal table must go to a set value before adjusting to target (Don't know for sure, just a guess). BG says fueling and many other factors will mess with the boost which is one reason he has a constant headache.
TurboTony
Okay, that explains your problem.
Any change in your turbo from stock will totally mess with the w/g calibration.
You are exactly correct about the problems with the stock w/g, they are very apt to overboost.
Nolan spent hours tuning the 20g on his and Q's truck. It is possible to get decent boost control with the ecm, but it requires incredible amounts of time and effort.
What turbo are you running? What exhaust housing?
i use a cheapy/simple boost controller on my truck. We never bothered working with the ECM boost control and I doubt we ever will. That might be something you will want to look at as well.
HTH
Tony
QUIKSUV
I don't remember for sure as I bought it in 1996. I got it from John Meyer's Turbo Specialties and it was a factory Mitsu turbo upgrade for the syty.
Are you just running a simple manual control?
TurboTony
Well upgrade could mean several things. I'm guessing that its a 20g but who knows what turbine housing it has.
The boost control is very finicky with the stock setup, thats why you see the duty cycle jumping around.
I'm running an in cab adjustable "boost commander" works well for me.
I have a pte style setup, so I have no idea what it would do for you.
I've never personally messed with the mitsu turbos, tuning for em, etc. My best advice is to search the archives and the BB for other peoples experience tuning for an "upgraded" turbo. I know Dig has spent quite a bit of time with the 20g, something about upgrading the spring in the actuator for better control.
Sorry, that's all I can offer you
Tony
ghettosled
SYTY SUPERSTORE
like i mentioned i would see if you have a v7 chip. If so, they usually work best on 100% stock trucks. A v6 seems to be a tad richer and smooth out the boost control on modified trucks and very strong running stock trucks.
Probably why the pitbull works ok for you, b/c it is very piggish (rich)
