UPDATE! Installed GReddy Type S....NO BOOST CONTROL!!
psmvchaser
I just installed a brand new GReddy Type S boost controller on my pte54. I now have no boost control. It just stays at the standard 12-13 lb range no matter how much I adjust it.
I followed the directions perfectly and double checked everything.
Looking for some ideas or if anyone has a similar setup, and they ran into any problems.
SyTyJedi
Jedi Council
Re: Installed GReddy Type S....NO BOOST CONTROL!!
Do you have pics of your install showing where each hose is hooked up?
psmvchaser
Don't know how to post pics.
The bottom (wastegate actuator) port is hooked up to the "COM" port
The top (compressor housing) port is hooked up to the "NO" port
The "NC" port is empty and I removed the plug per the instructions.
I do have power to the unit as it lights up and appears to function.
93 TY 2185
Email me what you have and as far as pictures and I'll post them for you.
Beavis
Still plays with trucks
He even called me and I looked at and it looks like it's right. This is a little strange... :dunno:
mmp142965
say it like you spell it!
I dont know if this helps, but I have the same boost solenoid and did not remove the plug, and it works fine. Maybe i missed that part in the directions??? I am not sure how much difference it would make either way, but I guess its worth a shot. pic here...
http://www.pbase.com/ty1770/image/56922226 "com" goes to the gate and "no" goes to the compressor just like you have it.
psmvchaser
That pic is exactly how mine is hooked up.
I guess I could try it with the plug in.
It just got cold here again, so it might halt my progress.
TYTILIDIE
METH HEAD
Did you try turning off the warnings?
psmvchaser
I'm not sure what you mean. Or how you do that.
TYTILIDIE
METH HEAD
You scroll down to the warning settings and set them for the highest boost setting possible. If you need further help you can PM me or give me a call. I may be able to help you out a little.
Syclone Rob
Its all ABOOT the SYTY eh
When you do resolve this issue.. can you please post your findings??!!... some threads I read regarding issues are left open.... :tup:
Daryl H
I had a Greddy Profec B with a bad stepping motor. Couldn't get more than 8 PSI out of it until it decided to help shell out my engine. Be careful with what you do.
psmvchaser
Well, ran it with the plug in the nc port....no change.
I have 3 ideas.
1. Could it be a vacuum leak? I have brand new silicone vacuum hoses so I don't think so.
2. I thought I read on someones post that you shouldn't use the fp regulator vacuum hose to tee off of for a boost gauge. Per the GReddy directions, I teed off of that line to send vacuum to the Main Unit. Could that be a problem on our trucks?
3. Maybe the unit is faulty? I plan on calling the tech line for help as soon as I eliminate every other possibilty.
What could be some other things to double check?
TYTILIDIE
METH HEAD
Did you check the warning settings? Does it start turning red when you get on it?
mmp142965
im thinkin maybe this is the problem. What do you mean by "Main unit" ? the only vacumn port you could have used on our trucks with any success is the fuel pressure/map sensor line. However this will mess the truck up. I T'd mine at the booster with RPM's brake booster hose kit. Before I had that, I just used stuff from home depot in the same location. here is the best pic I could find... http://www.pbase.com/ty1770/image/56917062 look on the back of the upper intake. I still have that thing if you want I can send it to you, or you can make your own, or order the one from RPM:tup:
psmvchaser
Well, rerouted the vacuum and used the front manifold port. No change. I rechecked everything else so unless I have the valve unit hooked up wrong, I have no idea what the problem is.
I'll be calling GReddy's tech line on mon.
mmp142965
good luck, hope it works out!
psmvchaser
Re: UPDATE! Installed GReddy Type S....NO BOOST CONTROL!!
OK, so I just received a brand new unit and hooked it up.
Heres what I have found so far: If I use the compressor housing, I get no more than 12-13 lbs of boost no matter what.
If I run the NO line tapped into the fuel pressure regulator line I get a little bit of adjustability, but it does not seem to be right. I had it on high boost with the knob turned about 2/3 of the way up and I was still only getting 20 lbs of boost.
I've quadruple checked every connection and called GReddys tech line numerous times.
I'm about to scrap this thing and go with a Blitz SBC ID.
Any suggestions before I do?
TYTILIDIE
METH HEAD
Dude you got it hooked up all wrong. If you wnat let me knwo and Ill explain it to you.
psmvchaser
OK, please do....I'm going crazy over here.
