Update on Build
welll after a long long while, (too long) My Sy is on its way to go vroom once again (for how long is yet to be determined), the build consists of a stock block, crank, eagle rods, unported Brodix heads, KB cam, Custom A/A, i deleted the AC and i am running an electric water pump, Aluminum Cell in bed, Aeromotive pump and stainless lines all the way, 321 stainless 1 3/4 headers with Merge collectors, and an Innovative 72, 83 pounds injectors and WB F.A.S.T. setup, CK performance did the tranny and im running a 9/11 converter (uh oh), anyway for anyone that is interested its very close and hopefully i can make it to Englishtown for the GM EFI nationals, are any of you going to this?, its July 12 I believe, also is there anyone that can host some pics?
thanks John S
yes i made the headers myself, i would offer them to the public but they were designed to work with my truck and thats all if you know what i mean, i could offer them if someone has the same build as mine, main thing is you have to switch to a borgeson or flaming river steering shaft, and delete the A/C
Thanks John S
I think www.sy-ty.com can host some pictures for you, if not I could through a few pics on my corvetteforum website. Are you going to do any run up at Epping? My sy should be mostly together after the 4th July weekend.
I need some exhaust work, WB O2 bung in the downpipe, remove stock cat and add on a new pipe to my borla exhaust. Does the shop have time for something like that? I could give you hand with your truck if you need a hand.
