Updated cross reference of substitute ECMs
Tooky
Serious about performance
As far as I know, the main cross reference for compatible ECMs is http://www.syty.org/old/promguide.html which is a little vague. I have found a better, more in-depth site for cross referencing a ton of GM ECMs from the same era. http://www.cruzers.com/~ludis/p4xref.html from this site. I thought his green & white chart near the top of the page was particularly interesting.
Our ECM was used in the following applications:
1987-1990 2.0 Turbo 4-cyl "LT3" VIN "M" motors, found in Sunbird, Skyhawk, Calais, Grand Am, and possibly Skylark.
1987-1988 2.3 Quad 4 16V "LD2" VIN "D" motors, found in Grand Am, Calais, and possibly Skylark.
And finally obviously the 91-93 SyTy application.
The reason I am bringing this up is because I just scored a remanufactured Turbo 2.0 ECM with PROM for $50 including the wiring harness (cut off 6" after the ECM"). I am hoping to use it to substitute my existing ECM and see which provides better results as far as system voltage and knock retard go. The PROM was a bonus, I understand this could be reprogrammed. Anyway, just a thought for any of you who are at wit's end chasing knock retard problems, it's another idea to try..
PS: Hint to anyone searching on eBay for these ECMs, try searching by part number or the other cars, sometimes you will find one that's the same part number as Syclone/Typhoon ECM but no one else will be bidding on it! The Syclone/Typhoon ECMs will almost always go for around $50 with no chip and no wiring harness.
smeagol
Check the prom, prolly can't use it because of the engine/vehicle specific ESC on the memcal.
I had/have the code for identifying the ESC per motor etc, but if you have the memcal broadcast code, you'll tell for sure.
Tooky
How about AMUW ? Thanks in advance!
PS: I can use this remanufactuered ECM #16198263 in my Syclone right?
<font size=-1>[ This Message was edited by: TookyCat on 2002-03-11 21:22 ]</font>
Falco
Great page Josh, thanks....
BTW, when I was last time in US, I was able to pick up a 1227749 for $35 on a yunkyard. It required some handy work, but got the prom and the wiring harness as well. It came out from a turbo Sunbird. 30 day return would have raise the prise with $8, but I didn't ask for it. :grin:
kbbeckius
According to the Hollander interchange (which I have on my computer :smile: ) The following will work:
Part Type 590 Electronic Module 03-12-02 11:09
Interchange 1865 93 GMC typhoon
Notes: Controller (ECM)
Engine code "M".
Calais '87 ECM (Controller, less PROM) 4-138(2.3L)
Cutlass '88 ECM (Controller, less PROM) 4-138 (2.3L)
Grand Am '87-89 ECM (Controller, less PROM) 4-121 (2.0L)
Grand Am '88 ECM (Controller, less PROM) 4-138 (2.3L)
Skyhawk '87 ECM (Controller, less PROM) (4-121, 2.0L), turbocharged
Skylark '88 ECM (Controller, less PROM) 4-138 (2.3L)
Sunbird '87-90 ECM (Controller, less PROM) (4-121, 2.0L), turbocharged
Syclone '91 ECM (Controller, less PROM)
Typhoon '92-93 ECM (Controller, less PROM)
I started looking at salvage yards too.
Thx Brad
Tooky
On 2002-03-12 08:43, Stanley Spadowski wrote:
AMUW isn't a syty code as far as I know, so it isn't gonna work.
No It's definitely not, that's the reason I found the page I mentioned in the first post :smile: So the chip isn't right, I knew that, BUT is the ESC half of the MEMCAL still compatible with the SyTy? If I had the EPROM reprogrammed could I still use that same MEMCAL? Or is the ESC calibrated differently for the SyTy chips versus the 2.0 Turbo chips? Thanks,
