updated, faster at part throttle.
Gnocide
turbo game burt reynolds
thanks to everyone who replied with ideas and here are the results: timing played a small factor why my truck and 5 or 6 other trucks that had the same problem on the last post. and my problem was a driver side broken motor mount lifting under heavy throttle and sending the knock sensor into retard heaven thus when you lift it is faster. anyone have an easy way to replace it?
sytyfreak
Thanx for the info! But I have done some datamaster runs and my truck only gets about 1-3 degrees of knock and is not always at WOT. How much knock you were getting at WOT???
Thanx!
Matthew Little
motor mount
motor mount
yeah sure when you have to put bearings in your truck and rebuild the front diff because of the last owner it is easy to get to. otherwise you will have to put those small hands to use. Both the mounts were completely shot on my truck when I got it, the ruber was not even part of the mount anymore. Hope you come down soon so I can blow you away.
Gnocide
matt if you get your ass to the meet at pittsburgh with erue, ill chin check your ass.
Mephisto
These trucks are cursed
ahhhh! so then timing does play a role in the cause of this??!!?
i hope that is the case! cause then my retard friend that "knows everything about engines" will be oweing me some money! cause the last time we checked my timing it was advanced 4* and i said to set that shit back to 0 and he claimed my truck runs better with it advanced, and it was getting dark so we didnt fix it...
now could advanced timing be messing with everything else in my truck?hence the reason my truck seems to bog under high boost in 3rd gear at like 75mph+?
Tydriver
TurboLS6 Powa'
Thanx!
For the record, it takes very VERY little throttle for the engine to torque over against an UNRESTRAINED engine mount. Its alot easier to attempt to rotate that 4.3L v6 that propel your 4200# brick down the road.
Dont believe me ? Open the hood on yer truck and do a powerbrake sometime and watch the engine dance...... Obviously dont launch the truck with the hood open and make sure nobody is standing in front watching in case you have a brake issue.
You'll be surprised how much it will move against an engine with BAD engine mounts.. I'm almost half convinced that they came from the factory with bad driver's side mounts.. LOL
vortecfiero
In general your 4 deg friend was sort of correct....
i found my nat asp L35 liked a 4 to 8 deg advance for day to day
driveing and out of the hole at low rpm BUT after 4000 rpm it fell
off big time (way overadvanced but no knock yet). Seting it at zero
would lose the great low end pull but at 4000 rpm it pulled nicely
so....
with a turbo i'll bet the overadvance thing could be that much worst
i will sooo glad when i get my project running (notice i didn't say
finished HA !) and datamaster will confirm or disprove may ideas
i have about some conceptual stuff.Oh ya... and laying waste
to some local rice a roni (young Italian gentlemen who modify
hondas because their parental units won't allow a red trans am... :wink:
j/k !
