Upgrade to 25G?
It's just a six
Super Member
Re: Upgrade to 25G?
Yes you could.
You would need to either weld some aluminum bungs to attach a stock wastegate actuator or run an external wastegate.
It would spool fast, maybe not as fast as a stock compressor wheel, with specs like: 77.96 mm / 60.46 mm(Exducer / Inducer ) it is going to be heavier.
But, once it starts to grab boost, the boost will come in much faster.
I believe the compressor wheel will have a super back style. So you will need the matching super back components rebuild kit, possibly some machining of the compressor wheel to fit.
Not a direct bolt on, but any competent turbo shop should be able to install it.
