Upper Ball Joint Installation Help
TNPhoon
1of28
Okay...doing the upper ball joints and wtf...
Drivers side: metal in top of arm, cup underneath.
Passenger side: both metal and cup were underneath the arm.
Have seen pics on here of setup like on drivers side. Which damn way is the correct way? Rivets have been punched out so they have been done before...just stuck on which is the correct way to install them?
NJ93TY
Re: Upper Ball Joint Installation Help
I'm pretty sure the metal plate goes on top of the control arm. I'm not home so I cant go downstairs and check my truck but I'm sure someone will chime in before then. If not I will check when I get home.
TNPhoon
1of28
The metal plate and the cup on top dropped in? Ive looked and seen these things installed likr 8 different ways so far. Lol. And like I said my passenger side is completely different from my drivers side.
Passenger side was: control arm on top, ball joint and cup underneath. My drivers side is ball joint on top, control arm, cup underneath control arm.
In the manual it appears both ball joint and cup should be above the control arm, I think, hard to tell....but Ithe hole in the control arm isn't wide enough for me to drop the cup in from above. And dont want to hammer the hell out of it and warp it. Could grind it a bit bigger. Or I have the wrong ball joints, and the ones that were on there before were the wrong ones?
Logan
I would think it would be better to have it on the bottom as that would place the weight on the body of the ball joint vs. just the nuts and bolts. I am just kinda thinking out loud though.
canadian
sy in progress
So the only thing holding that ball join to the A-Arm are those three nuts and bolts? Stock are riveted in which would seem stronger.
Logan
I stand corrected then. Still seems like a bit of a design flaw but it has been working on millions of S/T body trucks so that can't be wrong. Glad we got some finality on the issue.
TNPhoon
1of28
Got some different ones from napa. Didn't have that cup thingie and worked fine. But ran into other issues. Whomever all owned this truck before me can blow me.
TNPhoon
1of28
And ill post a pic up in a bit of the balljoints that were on the truck. Doesnt look like any of the above pics have the "cup" I was referring to.
CC801
Upper ball joint is a follower joint, not a load bearing joint.
Cup placment may vary between manufacturers, but the ball joint plate is on top of the arm with the stud going thru the hole. I used moogs and the cup went on top of the control arm as well.
They owe me at least one blow in there also.
You guys could blow each other and be even.
That was only fun the first 3 times, 4th time left me with bad memories as I didn't realize Nate still had his retainer in. :rant:
TNPhoon
1of28
My bad. I thought it would make it feel a little better.
So here's some pics of what I was talking aboot.
Passenger side where balljoint + "grease cup" were mounted below the arm:
Drivers side where balljoint is mounted on top of arm, "cup" below:
Left side: replacement ball joint. Right side, ball joint that was in there. The "grease cup" wouldn't fit through the hole, even with a bit of hammering.
Didn't want to grind the hole bigger so went down the street to NAPA to see the ball joint they show for Typhoons, which fit perfect:
cheatham2492
FYI the instructions for the RPM coil overs show
the ball joint and cup under the bottom of the top A-arm.
I do know that it's located on the top of the stock A-arm
But how ever they are riveted in and are super strong from the factory.
I have mine on the bottom as of now. Because as mentioned before ...have the ball joint sandwiched and the pressure is on the arm and not the little nuts and bolts they give u.
More investigation is needed.
Cheatie
Quickstop [UK]
Combating adversyty.
The lower balljoint is what supports the weight of the truck. All those 4 little bolts have to do is hold the upper a-arm to the spindle which they easily do.
Notice the form factor for the upper and the lower as well - upper has a long cylindrical tube like body, lower is rounder. The cylinder is designed to go through the upper a-arm. It's not structural in that it has anything to do with movement but it does allow the upper ball joint to protrude far enough.
When all is said and done, if the dimensions of the ball joint are the same and the factory had them on the top of the a-arm, it seems sensible to reproduce what was done at the factory and that's saying nothing about possible alignment/travel issues.
