UR6IX PLUG GAP vs UR6
SYCLONE#1531
'MOFOFAST
Im swapping to the UR6IX plugs. I was running the standard UR6 plugs gapped at .022 with the msd box with no issues.. I have now added methanol injection and shooting to run aprox 27psi with the 6766cea turbo. Any one have a idea for gap range for my setup with the IX plugs? Not sure if I gap the same as the standard plugs?
Syclone22
Re: UR6IX PLUG GAP vs UR6
Well i have good results with the Denso IT16 for street
use and with nitrous i switch to IT24 these plugs have
a coppercore and gap both to .024 inch !! ;)
Sean Krupa
Moderator
Quick question. How are you guys running such a small Spark plug Gap? I run .028 with UR6 plugs. Heard it was good with Alky. Now with the Bigger turbo, wondering if I should leave it.
Syclone22
As long as you don,t notice any misfire just keep the gap
at .028 i use this for street my setup !! :tup:
qbnkiller
Conflaguration Specialist
Not to stray off topic, but I am running an NGK -9 heat range plug on E85 at 0.030" with no issues. Also running an MSD 6 box and coil, 20# boost.
Raist103
UR6IX = issues on any non n/a car. just my 2cts.
SYCLONE#1531
'MOFOFAST
Installed the ur6ix's gapped at .022 today, Definetely improved my idle! Going to Paradise drag strip 1/8th mile Sunday for some testing. Im hoping to see some 6.8/6.90s times.
It's just a six
Super Member
Mine are gapped @ .028", no problems running up to 25 psi & spraying meth w/Alkycontrol system.
I run a plain MSD6 box, w/stock HEI.
I think I could run .032" w/no problems.:2cents:
