Urgent!!! Timing 0
Injected1
The tab above my harmonic balancer is rusted and I can't see where 0 is. Can someone please take a pic of there timing tab ASAP. Trying to get this motor running tonight, can't set base timing.
bezerk
Re: Urgent!!! Timing 0
sorry man, couldn't find a pic. but why don't you set it in the middle first. being of 1 or 2 degrees is not making a huge difference.. it should run and be drivable.. if you have an aftermarket chip like the ultimate it will retard 2 degrees extra when knocking.
there where pics here though
Mine's not in front of me but if memory serves look for some saw teeth then a slightly larger notch then a larger tang. -0- is in the middle of the larger notch, close to where the tang sticks out.
Edit: Dave beat me to it...
HTH
