Re: USB Cable adapter
Belkin F5U103 USB-Serial
Thats the one I and most others use.
Once hooked up, go to File > Record ALDL Data...
Then on that menu, go to Options > Advanced >
Disable the CCM Handshake
Then go to Options > Advanced >
Serial Communication Timing...
Once there, I have my settings set to the following numbers
Receive Timeout : 180
Transmit Timeout: 180
BitBang Timeout: 180
ALDL Link Timing: 199
I believe the last one is the critical one which may vary depending on your setup. If you cannot connect with it at 199, try going to 195, then 190, 185....ect until you get a connection. If it does connect but drops out of wont stay connected for more than a few seconds, then try going up or down by a digit or two to find your best link timing number.
Hope that helps.
